In the world of software development and deployment, Docker has had a significant impact on the way we develop, test and deploy applications. Docker, an application containerization platform, has revolutionized the tech industry with its efficiency, flexibility and scalability. In this article, you will learn why Docker is so popular, how it differs from traditional methods of service delivery and what benefits it offers. I will also use a simple example to show you how Docker is used, ports are released, data is stored persistently and environment variables are integrated.
What is Docker? 🐳
Docker is an open source platform that enables developers to package, deploy and run applications in containers. Containers are lightweight, portable and self-contained software units that contain everything an application needs to run: Code, runtime, system tools, system libraries and settings. These containers can run on any platform that supports Docker, ensuring a consistent environment from development to production.
Conventional service delivery
Before Docker, service delivery was often complex and error-prone. Applications were installed directly on physical or virtual machines, which led to various challenges:
  • Environmental issues: Differences in the development, test and production environments often led to problems that were difficult to reproduce and fix.
  • Resource utilization: Virtual machines consume significant amounts of system resources, as each VM requires a full operating system and virtual hardware.
  • Scalability: Scaling up applications often meant that new virtual machines had to be created and configured, which could be time-consuming and expensive.
  • Isolation: Applications on the same machine could interfere with each other, which could lead to stability issues.
Docker vs. traditional methods 🆚
Docker solves many of these problems through its containerization technology:
  • Consistency: Docker containers provide a consistent environment regardless of where they are running. This means that an application that works on a developer laptop will also work on a production server.
  • Efficiency: Containers share the same operating system kernel, which makes them more lightweight and resource-efficient compared to virtual machines.
  • Fastness: Starting and stopping containers is faster than virtual machines, which shortens development and deployment cycles.
  • Isolation: Containers are isolated from each other, which means that problems in one container do not affect other containers.
  • Portability: Containers can be easily moved between different environments and cloud providers, which increases flexibility.
Advantages of Docker 🚀
  1. Faster development cycles: Docker enables developers to test and deploy their applications quickly. By using containers, developers can develop, test and deploy an application in a consistent environment. This reduces the time spent fixing environment issues.
  2. Scalability: Docker containers can be easily scaled by simply launching additional instances of the containers. This makes it easier to scale applications up and down as required.
  3. Efficient use of resources: As containers share the operating system kernel, they require fewer resources than virtual machines. This leads to more efficient use of system resources and reduces infrastructure costs.
  4. Security enhancements: Docker offers various security features, such as container isolation and the principle of least privilege, to ensure that applications can run securely.
  5. Flexibility and portability: Containers can run on different platforms and in different environments, enabling high flexibility and portability. This facilitates the migration of applications between different cloud providers or from local data centers to the cloud.
Docker's impact on the tech industry 🌐
Docker has fundamentally changed the way companies develop and deploy software. Some examples of how Docker has impacted the tech industry:
  • Startups and SMBs: Docker enables smaller companies to optimize their development and deployment processes, giving them a competitive advantage. By using containers, these companies can respond more quickly to market changes and bring innovative products to market faster.
  • Large enterprises: Large enterprises also benefit from Docker by modernizing their existing applications and deploying new applications faster. Companies like Spotify and eBay use Docker to run and scale their microservices architectures.
  • DevOps culture: Docker has helped spread the DevOps culture, where collaboration between developers and operations teams is improved. By automating build, test and deployment processes, organizations can work faster and more efficiently.
  • Cloud-native applications: Docker is an integral part of the cloud-native movement, where applications are built from the ground up for the cloud. Containerization and orchestration with Kubernetes are key elements of this movement, helping organizations build highly scalable and robust applications.
Building a Docker Image and Deploying 🏗️
A Docker image consists of multiple layers that build on each other. Each layer represents a change in the container's file system, such as the installation of packages or the copying of files. These layers are immutable and are retrieved from the cache when needed to speed up the build process. Docker images can also build on other Docker images. Here is an overview of the layers and caching in a Docker image:
  1. Base image: The first layer of a Docker image is the base image, which is specified in the FROM statement. It contains the operating system and basic tools.
  2. Working directory: The WORKDIR statement sets the working directory in the container in which subsequent commands are executed.
  3. Copying files: The COPY statement is used to copy files from the build context to the image. Changes to these files create new layers.
  4. Installing dependencies: The RUN statement executes commands, such as installing software packages. Each RUN statement creates a new layer.
  5. Environment variables: The ENV statement sets environment variables that are used in the container.
  6. Exposed ports: The EXPOSE statement specifies which ports the container will use.
  7. Start command: The CMD statement defines the default command that is executed when the container is started.
Docker in practice: A simple example 🛠️
To better understand Docker, let's look at a simple example of how to deploy an application in a Docker container, expose ports, persist data and include environment variables. In this example, we'll use a simple Node.js application.
Setting up the Node.js application
Create a directory for your project and create a simple Node.js application:
mkdir my-docker-app
cd my-docker-app
Create a package.json file:
  "name": "my-docker-app",
  "version": "1.0.0",
  "description": "A simple Node.js application",
  "main": "index.js",
  "scripts": {
    "start": "node index.js"
  "dependencies": {
    "express": "^4.17.1"
Install the dependencies:
npm install
Create an index.js file:
const express = require('express');
const app = express();
const port = process.env.PORT || 3000;
app.get('/', (req, res) => {
  res.send('Hello, Docker!');
app.listen(port, () => {
  console.log(`App is running on port ${port}`);
Create a Dockerfile
Create a Dockerfile in the root directory of the project:
# Use a Node.js image as a base
FROM node:14
# Set the working directory in the container
WORKDIR /app
# Copy the package.json and package-lock.json
COPY package*.json ./
# Install the dependencies
RUN npm install
# Copy the application code
COPY . .
# Set the environment variable
ENV PORT=3000
# Expose the port
EXPOSE 3000
# Start the application
CMD ["npm", "start"]
Build and start Docker container
Build the Docker image:
docker build -t my-docker-app .
Start the Docker container and release the port:
docker run -p 3000:3000 my-docker-app
The application should now be available at http://localhost:3000.
Persistent data storage
To ensure that data is stored persistently within the container, you can use Docker volumes. Create a volume and mount it in the container:
docker volume create my-volume
docker run -p 3000:3000 -v my-volume:/app/data my-docker-app
Include environment variables
You can set environment variables when starting the container:
docker run -p 3000:3000 -e PORT=4000 my-docker-app
In this case, the application will run on port 4000.
Conclusion 🎉
Docker has revolutionized software development and deployment by enabling developers to package applications in isolated, portable containers. This offers numerous advantages over traditional methods, including consistency, efficiency, scalability and security. The impact of Docker on the tech industry is enormous, as it helps companies of all sizes to optimize their development and deployment processes and bring innovative products to market faster.
👉 Have you already had experience with Docker? What advantages do you see in using containers? Share your thoughts and questions in the comments!
