You probably know the feeling: A new project is about to start and the first big question is, how do I style this thing? Write classic CSS, the way we have known it for years? Or go with Tailwind CSS, which seemingly every other developer swears by? Spoiler: Both approaches have their place. But when is which actually worth it? That is exactly what we are going to figure out here. 💪
Tailwind CSS is perfect for rapid prototyping and team-wide consistency. Vanilla CSS shines when you need full control, for small projects, and with component frameworks that have scoped styles. The best solution? Often a mix of both.
What Is Vanilla CSS Anyway? 🍦
By Vanilla CSS, I mean plain, native CSS, no frameworks, no utility classes, no build tools. You write your own classes, define your layout, your spacing, your colors. Everything by hand. That might sound old-school, but it has solid advantages:
- Full control: You decide on every single line.
- No overhead: No additional dependency, no build step required.
- Learning effect: You truly understand what is happening.
- Small bundles: If you work cleanly, only what you actually need ends up in your CSS.
Especially with modern features like CSS Custom Properties, Container Queries, CSS Grid, and :has(), native CSS has become extremely powerful. Many things that used to require a framework can now be done natively.
What Does Tailwind CSS Do Differently? 🌬️
Tailwind CSS is a utility-first CSS framework. Instead of writing your own classes, you combine predefined utility classes directly in your HTML:
<button class="bg-blue-500 text-white px-4 py-2 rounded hover:bg-blue-600">
Click me
</button>
At first glance, that looks chaotic, but it has its charm:
- Fast development: You do not have to invent class names or switch between files.
- Consistency: The design system is built-in, spacing, colors, breakpoints are predefined.
- No dead CSS: Tailwind automatically removes unused CSS (PurgeCSS).
- Rapid prototyping: For quick prototypes, Tailwind is hard to beat.
Head-to-Head Comparison 🔍
Let us look at a simple card component in both variants.
Vanilla CSS:
<div class="card">
<h3 class="card-title">Title</h3>
<p class="card-text">Description</p>
.card {
background: white;
border-radius: 8px;
padding: 1.5rem;
box-shadow: 0 2px 8px rgba(0,0,0,0.1);
.card-title {
font-size: 1.25rem;
font-weight: 700;
margin-bottom: 0.5rem;
.card-text {
color: #666;
line-height: 1.6;
Tailwind CSS:
<div class="bg-white rounded-lg p-6 shadow-md">
<h3 class="text-xl font-bold mb-2">Title</h3>
<p class="text-gray-500 leading-relaxed">Description</p>
Immediately noticeable: With Tailwind, you do not need a separate CSS file. Everything happens directly in the markup. That is both its strength and its weakness.
When Is Vanilla CSS Worth It? ✅
- Small projects without a build pipeline
- When you need full control over your CSS
- With component frameworks that have scoped styles (Angular, Vue, Svelte)
- When you want to fully leverage CSS variables and modern features
- Projects where semantic class names matter (accessibility!)
When Is Tailwind CSS Worth It? 🚀
- Rapid prototyping and quick MVPs
- Teams that need a consistent design system
- React/Next.js projects where Tailwind integrates well
- When you do not want to deal with CSS naming conventions (BEM, SMACSS, ...)
- Large teams where consistency is more important than individuality
The Downsides Nobody Mentions ⚠️
Tailwind:
- Your HTML becomes extremely long and cluttered with complex components.
- You are locked into the Tailwind ecosystem, migration is costly.
- Custom designs outside the default system require a lot of config work.
- Dynamic styling at runtime? Not so easy.
Vanilla CSS:
- In large projects, CSS can quickly become hard to maintain.
- Naming is hard, after 50 components, you run out of good names.
- Without conventions like BEM, you will end up with spaghetti CSS.
- Finding and removing dead CSS is tedious.
My Verdict 🎯
There is no "better" or "worse". It depends on your project and your team. Personally, I like using Vanilla CSS with Custom Properties for projects where I need full control, especially in Angular with scoped styles, it just makes sense.
For quick prototypes or when working with a team that needs a unified system, I go with Tailwind. It saves time, and the built-in consistency is worth its weight in gold.
My tip: Learn both! If you understand native CSS, you can use Tailwind more effectively, and vice versa. And maybe the best solution is a mix of both. 😉
Here are some useful resources: Tailwind CSS Docs, MDN: CSS Custom Properties and MDN: CSS Grid Layout.
What about you? Team Tailwind or Team Vanilla? Let me know in the comments! 👇
